My kx250 2002 winter rebuild
here is my rebuild of my kx250 2002 not finished yet, but almost. I don't have alot of pictures about my build but always fun to share.
here is the kx with my brother's rm250 2002
the first 2 hours of dis-assembly
My work bench and my tool box
my first order tires, cables, all the bearing (suspension, swing-arm, linkage) fork seal and bushing...
My cylinder was done and my piston had a crack on the skirt (no pic of the piston
test fit some color (painted old plastic too see) and my ebay pipe
polished the exhaust tip, painted the tube and repacked it, looks like new
Bought new gear   :lol:
my shock completely rebuild with new race tech spring
My new cylinder  :evil:
My roller both suspension rebuild + all bearing, repoked rear wheel and new tires
engine rebuild time...        DONE
Edited by Adam86
had to modify a intake boot that i bought on ebay from a kx250 1995 they are the same except for the notch in the corner for carb clearance
it is almost done still waiting on the clutch hub and a water pump bearing the number plate will be black and the fork guards too
