6.0Kg rear spring installed need sag specs
I weight 250 installed my new spring i measured with the bike on a stand with no weight at 571.5mm i took it off the stand and with me on board i measured 482.6mm which equals about 88mm is that at an acceptable range?
Edited by fuentes52
Were you wearing all your riding gear, did a friend help you?
90mm-100mm is where you should be.
With the correct spring, you should also have 10mm-25mm of unladen sag, that's the bike under it's own weight.
yes i was wearing all my gear. Ill have to back the collers out and remeasure thanks
