Do you check motor oil in a 07 crf250r when its hot or cold...
Hey iv got an 07 crf250r.... just wondering how much oil to put in it... iv changed it before and filled it to just under the full line on the dip stick when its warmed up.is this ok. it is also bel ray thumper 10 w 40.... its a good oil..
You should try and find your self a owners manual, it's really good at describing all the maintenance procedures including suspension and carb set adjustments.
It says check oil hot, let sit a few min. level, and just push in dip stick. I would keep the level in the top half of the range though, since there is so little oil in there. The volume is  0.7 liters  and yes, thats good oil.
