650R Uni filter
I bought a Uni filter, and it didn't fit at first. The seal foam was over-glued to the filter foam, so the frame didn't go into it all the way. Plus the frame was a little too big, so I ended up grinding two of the corners down a little. Does the uni frame eliminate the need for a backfire screen?
I only run the Uni filter for the 650R with the included plate.  I do not use the stock backfire screen with it.
