what better time to learn than now?
Hi all, I dont frequent this Sub forum as often as others but! i have a 98 kx250 and Need to rebuild my shock. i have done many a set of fork seals and bushings through work and on my own bikes, and have many different styles down. i'd really like to avoid a 100+ dollars of having someone do it for me and would really like to do it myself. i know topics such as this have been posted before, but i'd like to have a place i can go to hold my hand through any questions or concerns i may have, there will be pics, and there will more than likely tears :cry:
i have a service manual from Kawasaki for my bike that has pretty decent instructions for tear down and re assembly, only thing i am in a fog about is what kind of suspension fluid to use, it suggests belray se2 #40 or the kyb oil, what would that translate to in say a maxima fluid?
and in advance, thank you to everyone that decides to join in and laugh point and maybe help ;)
Edited by Theeebalz
You can use a 2.5wt to 5wt most prefer the thinner oils but a lot of manuals state 5wt
20140428_202712_zpsc4991ebe.jpg springs off
20140428_202717_zps49c0a3e8.jpg shocks drained
20140428_203041_zpsa115c34f.jpg bladder clip out!
20140428_203052_zps2757fa41.jpg this picture doesn't show it but im going to have to buy a new bladder, the valve must have had a crack or was stressed already, put my tire valve holder tool on it to aid in pulling it out and it snapped before i even really pulled! damnit, ohwell didn't look in the best shape around the seam anyways. :banghead::facepalm:
20140428_210136_zps69aaaea8.jpg shim stacks right? do they looks like an appropriate order from right being top to bottom on left? theres also a thick washer
20140428_210245_zps83940f89.jpg cleaning parts.
20140428_212331_zps87684172.jpg clean and organmanized :ride:
alright first question, never tried valving or anything of the sort, but if i wanted to plush it up even in the slightest (not going to try right now) how would i tackle the task? where would i acquire new shims etc?
