2004 KX250F Plastics
I'm new to this as I just got off of a CR125.  I have a 2004 KX250F and was wandering if any other plastics fit or if there was a brand that offered the new style plastics for it.
newer front fender will bolt up, rear may need to drill. shrouds will not work unless you cut and drill. oem have the best/cleanest fit as most of the aftermarkets don't fit the greatest.
Also plastics from an 04 or 05 rmz250f will work as well if you want a yellow bike. That is literally the only difference between the kx250f and suzi-q in 04 and 05.
I also just put a polisport kit on my 06 kx250f. The front and rear fender look really clean and fit up good. The rad guards are decent, but the number plates were pretty cheap. The exhaust side ended up melting on my pipe, but I do have a bent sub frame.
