2002 kx 85 bogging at only full throttle after dirt inside gas container
What does your spark plug look like..
Have you tried lifting the needle one notch ?
When was the last time the engine was rebuilt, top and bottom?
Chasing a jetting issue is usless if you have a worn engine, it'll affect jetting.
Can try the needle but if it makes no difference I'd start with a compression test and a leak down test.
Well the spark plug is black inside I have not changed it yet I just rebuilt the entire motor top and bottom end my bike was running fine until my cousin mixed some gas up and the gas tank was dirty.
Clean the tank, carb and mix a new batch n see wat happens
I cleaned the gas filter out of the gas tank but didn't clean inside the tank I will clean the inside of my tank today after I run the rest of the gas out what is left and I think my float level may be a tad bit off I'm not sure if I have it set right
