02 RM250 "Freshening Up"
Its time for me to clean up my bike a bit. I plan on powder coating the frame, replacing bearings, bushings, and replacing what I can afford. In addition to the "bling", I'll also be rebuilding the suspension, fixing the dent in my pipe, and hopefully purchasing new reeds. The motor has a brand new Wiseco piston and the top end looks good but I have never cracked the cases on this, or any bike before. Runs fine.
Anyways, I have a couple questions for the experienced on cleaning this bike up. First, how can I get rid of that gross rusty dirt buildup? It is easily seen on the bottom of the case. Second, is there a trick to breaking tight bolts? Cant get anything loose on the linkage. Heat?
65c998c3-d042-4765-a0be-4d9ce32da93e.jpgd69d1a03-64e4-432a-94e9-d907e3a759c8.jpgIMG_0305.jpg
Lastly, did Suzuki weld their frames like this or is a previous owner trying to cover something up? Assuming it is stock by the way its painted over.
Edited by Wiski
A soda blaster would be best but scotch bright/toothbrush would clean it. Put some lubricant on the threads of linkage bolts
I'll pickup scotch bright and a toothbrush tonight. Got the bolts off with a torque gun and patience. Replacing springs and I'm getting the frame powder coated gloss black Wednesday.
I removed the bottom end of the rear shock to swap the springs. I didn't realize there was pressurized shock oil on the other end :facepalm:  What a mess that made!
I thought about powder coating the frame too instead I bought a cheap gun did a couple of covers and did a little freshening up my self  this is my 02 250 25edf804-d778-45a8-a70d-b4f084154ce6_zps
Beautiful RM. Makes me so eager to get mine back together.
I built a homemade soda blaster and had some fun cleaning the carb. After taking the picture, I took it apart again and blasted it for a second run. Missed some dirt.
Has anyone soda blasted the whole case before? I imagine I'll need a makeshift plug for the coolent holes and something to block the
driveshaft.
Otherwise I'll just scrub it.
Edited by Wiski
