Are my reeds bad?
I have 99 cr125 that just started to act wierd. The Rpms will not drop after I pull in the clutch and it has no powerband and it will hardly not start. So I read that my top end might need to be rebuilt so I did a compression test and with 10 kicks cold it was 180 psi. So I heard that your reeds can get cracks and it can do that so I took them out and I'm going to take them to a shop tomorrow but I thought I could see what you guys think about them here's some pics.ImageUploadedByThumper Talk1398734609.292917.jpgImageUploadedByThumper Talk1398734630.648061.jpgImageUploadedByThumper Talk1398734654.744611.jpgImageUploadedByThumper Talk1398734672.014536.jpgImageUploadedByThumper Talk1398734704.477835.jpgImageUploadedByThumper Talk1398734721.485517.jpgImageUploadedByThumper Talk1398734737.478447.jpgImageUploadedByThumper Talk1398734751.213069.jpg
I have 99 cr125 that just started to act wierd. The Rpms will not drop after I pull in the clutch and it has no powerband and it will hardly not start. So I read that my top end might need to be rebuilt so I did a compression test and with 10 kicks cold it was 180 psi. So I heard that your reeds can get cracks and it can do that so I took them out and I'm going to take them to a shop tomorrow but I thought I could see what you guys think about them here's some pics.attachicon.gifImageUploadedByThumper Talk1398734609.292917.jpgattachicon.gifImageUploadedByThumper Talk1398734630.648061.jpgattachicon.gifImageUploadedByThumper Talk1398734654.744611.jpgattachicon.gifImageUploadedByThumper Talk1398734672.014536.jpgattachicon.gifImageUploadedByThumper Talk1398734704.477835.jpgattachicon.gifImageUploadedByThumper Talk1398734721.485517.jpgattachicon.gifImageUploadedByThumper Talk1398734737.478447.jpgattachicon.gifImageUploadedByThumper Talk1398734751.213069.jpg
You can look at the inside when they are mounted in the cage held up to the light. If you see cracks of light i'd replace the pedals .
There should be an allowable gap spec between the reed valves and the reed cage (the area you are seeing light) the owners manual/service manual will have the spec, you just use a set of feeler gauges and go from there. Make sure the mounting screw is torqued to spec. I had a slight amount of light that shinned through on a KX85, measured, and it was well within spec. Also make sure they are clean and crack free I am not a pro by any means but they look like they have pretty good amount of gap and wear. Hopefully someone else can chime in.....
2006 KX85 / 2012 KX250F
2012 KX450F / District 6 #225
Instagram + Twitter: Schearer225
My local shop said that I could flip them and it would help. I'm trying to get a quick solution because I'm gonna trade it when I get it fixed.
Edited by pain99
