What head will work on 250 RMZ
Hey, i would like to know what heads would fit on 04. where would the best place to get one from? I hear 04-06 are the same but not sure if valves are the same or not. Thanks for reply and help.
Yes the valves are the same and you can fit a head from 05 or 06 model. As for the best place to get them ... The only place I can think of is ebay
Get an 06 head. Much more reliable than earlier years
Ok so an 06 is better? What are the changes? eBay is the place to look , what about the cams. I'm gonna need an intake for sure ... Is the 06 cams the same also ? Thanks
Yep the cams are the same also. The engine has very little changes and it stays the same across 04-06 also you can search for a head or cams whatever you need for kawasaki kx250f 2004/2005 I'd also say the 2006 model but I'm not entirely sure for that one. The kawasakis and the suzukis these years are the same bikes with different plastics so the heads/valves/cams/bottom ends are the same.
