Spring or stack
I have a 2007 yz250f that i purchased used and had been set up for a 150lb novice mx rider from factory connection. While i am a novice mx rider i am about 40lbs heavier not including gear. I know i have to change the springs but will the revalve work for me or will that need to be changed as well. how much does weight have on a stack?
Hardly any difference on compression and a small difference on rebound , you might get away with the rebound stack you have and the compression will be okay Imo
