I need one of these! BAJA NO PINCH
Man I must be behind in the times!
https://www.youtube.com/watch?v=hU1M6LlNp9U
BAJA NO PINCH 1001 - Tire Mounting Tool w/ 20mm Axle Shaft - for Motorcycle and Dirt Bike Enduro and Motocross
Price: $89.95 + $10.95 shipping
In Stock.
Ships from and sold by Baja No Pinch.
  • No more pinched tubes when installing a tire. Powerful rack and pinion system. Components custom CNC machined in the USA.
  • 6061 anodized aluminum bracket and axle shaft for light weight. Steel handle and bead push rod for high strength. Black oxide treated for surface protection.
  • Strong and light weight system - perfect for taking on the trail or off-road. Total weight 1.8 pounds - hardly noticeable in your travel pack. Takes the hassle out of tire installation.
  • The Baja Tool comes with a 20mm axle shaft. If you need a different size, please order either the 25mm sleeve, the 15mm or the 17mm shaft accessory. Note: the 15mm and 17mm shaft adapters are perfectly designed to screw in and replace the 20mm shaft that comes with the Baja Tool and the 25mm sleeve is meant to fit over the original 20mm shaft.
  • The tool breaks down into three parts, with the longest part being 12 inches. These parts will roll up into a compact bundle and at 1.8 pounds are hardly noticeable in your travel or fanny pack.Pinched inner tubes are history when you install a motorcycle tire with the Baja "No Pinch" tool.
 See more product details
  • Like 2
stupid ad banner blocks the view of the how the guy was using the tool in the video, really neat product if I could just see how to use it!
When youtube pops up the banner ad, click the X in the right corner to close it.
