Bar clamp. Will these fit? (Fat bars)
So first picture is my bar clamps now.
Second picture will these work the same?
Any difference at all?
Where could I possibly get the same bar clamp I have now?
The one piece ones.
by the way MIKA METALS IS THE BEST PERIOD.
Spacing on the bolts is different depending on the clamps. I have mixed and matched to come up with the right size but it's not a universal thing like some bike parts are. You might take a measurement and write the manufacturer.
well that's the thing. the holes to my triple clamp wont move. but the first picture is the one I have now. I bent it... it is a one piece
the second is the mika 2 piece so how would it matter if the bolt spacing is different? just curious as to that.
I run mika bars and im just wondering if the clamps work as I have always run the 1 piece rather then 2 separate
The bolt spacing I am talking about is the 1 1/2 or so inches between the two bolts gripping the bar. That spacing varies depending on manufacturers.
The distance between studs is going to be a standard thing for your bike if you are running the stock top triple which you appear to have. Aftermarket triples have different stud spacing so a top one piece would need to fit that.
You should hit up Scotts for a one piece top. They make them to fit their dampers but also plain. Every spacing you can imagine. Top quality and great people.
