Polaris 2005 Sportsman 500 HO ECM Enable
I have what appears to be a failed ECM. Before I buy a new ECM I would like to make sure the ECM is properly enabled. What is supposed to be on the ECM Enable wire? Ground? 12 volts? That wire goes to a buss with many wires. It seems that the enable state would change as the ignition switch is turned on and off. John.
Check to see if it has a recall form Polaris , I have a 05 500 scrambler 4x4 . and it had a recall on it , would start fires even if switch was off , Bought it 3 years ago used and was looking for some up grades , and seen it some web sight . Called up Polaris and they fix it for free ,
