DRC 602 install.. Couple Basic Questions
Just a quick couple questions on this.. when installing the front flasher brackets, do the fork clamp bolts need to be torque'd to spec or just tightened snug? (if so, can someone let me know what the torque spec is).  Also should i hit these bolts with lock tite when reinstalling? sorry for the basic questions.. just in the process of learning :)
Yes the fork bolts need to be torqued.
Top fork bolts for an S / E Model: 21.5 ft-lbs
Lower fork bolts for an S / E Model: 23.0 ft-lbs.
I suggest you download this and print it up for your garage. : http://dwulet.com/bikes/docs/Torque_DRZ400S.PDF
Doesn't have eveyrthing, but has most of the common stuff.
