Inside a 2014 350 EXC-F muffler
Just thought some of you might want to see what is inside. Older EXC used to have a smaller diameter piece of pipe inside to lower the sound. There is no such thing in the 2014 model. The little screen at the end of the muffler that you can see from outside (not the spark arrester) is removable. In the 12-13 there is a ring that is screwed and comes off easily, but is welded on the 2014. You can drill a hole in the screen and pry it out. The ring stays there and it makes a nice job.
Edited by ti-ben
What seems like the bottom of the muffler is in fact the middle, there seems to be more packing in the first half.
Here's some pictures of the screen removed.
Good info thanks. I have 2014 ktm 500exc and plan on (if the bike ever seems to lack power) opening up the muffler but the 500 has 2 screens one right next to the other. Was there only one on the 350 ?
Yes it's the only one.  I thought that they both had the same muffler?
So did I...same part number on the muffler as the 350 but maybe thats just the outer shell part number, dont know but when i shine a light in there i can see 2 screens.
I will be very surprised if you think it lacks power.  Run up to 6th gear full throttle and you'll be convinced that it's got plenty.  I let off at 85mph and it was still pulling hard.  :D
Yeah lol... Right know its not even broke in and seems to have insane power :jawdrop:
p/s I did buy your TPS tool and plan on playing around with that on mine and my friends 2013 350 exc. :thumbsup:
Edited by mojave1
after you d smog and adjust the TPS it will run like a whole new bike down low!
I plugged the large hose on the right side and disconnected the hose to the tank before I even rode it,runs smooth. Is there something else I should disconnect?
I want it to still look legal just in case of the LEOs.
Unplug the air valve under the throttle body, that would be the last piece to disable. I do a lot of really slow riding on mine and I noticed a pretty bad stumble when you barely cracked the throttle with the stock setup. After desmogging and adjusting the TPS this was completely resolved. if yours has no stumble then you might not need it. :-)
Did you half to cut both out or did they pull out like they were pressed in ?
I put a 3/8” socket extension on them and gave it a good whack with a 2lb hammer. It shoved them in and I picked them out with the hook from my spring puller.
I've gone from a Yz250F to 2014 KTM 350 EXC-F   and I love it so far, but I do have a muffler question;  I've noticed that the outside of the muffler is wicked hot (cant even touch it) compared to my Yz and my friends WR. I can actually leave my hand on the WR and YZ after riding.
Is this normal for this bike or is it a KTM thing?
The end cap on my 2014 500 exc gets super hot and stays hot for a while also.
