Blinkers
I've got a 300xcw with a baja designs dualsport kit, and I have already destroyed both rear blinkers. One of the lenses broke off of one blinker and the other just fell off completely. I'm thinking that the vibration from the motor is what caused them to break and for the other one to come loose and fall off. I've only put about 250miles on the bike since the kit was installed. Both broke/fell off on the same trip, which wasn't a very hard ride at all. So my question is, has anyone else had a plated 2stroke and what did you do for blinkers? Other question is, could you run a set of flush mount LEDS in the rear and regular blinkers up front? Or would you have to run LEDS in the rear and front?
Sent from my iPad using Thumper Talk
