Stripped Oil Inspection Bolt Hole
After an unsuccessful check of OEM parts on-line I was wondering if over sized bolts are available for stripped RH Case Cover holes, specifically the Oil Inspection Hole.
Recommended alternatives?
If you can get it back in and seal it up somehow (jb weld) example let it cure and not use it it anymore just use the big inspection plug right beside it !
Yeah, seal it up good. Clean it up with carb cleaner (what's left of the threads and the screw threads) then put some green collar sealing loctite in there, assemble it and let it dry 24hrs before adding oil and leave the oil fill plug out to aerate the inside while green stuff is drying. That sucka ain't ever gonna come out.
