Enter changeable wheels
I'm clueless but some research might provide the answer.  Look up the part description for the bearings in both wheels.
The x has a 25mm rear axle and a 20mm front.
The bearings are
front  6904
rear  6905
Those numbers are in the part description; in these bearings the the last digit times 5 is the bearing ID so 4 indicates a 20mm ID, and 5 indicates 25mm.
Do the same for the 250M.
The 6904 bearings have a 37mm OD and the 6905 have a 42mm OD,  worth knowing because sometimes wheel swaps with incompatible axle sizes can be done by swapping in different bearings. More info by web searching Metric Bearing Sizes.
