air psi vs springrate
look at www.valvinglogic.com.
you can download a fantastic software to compare common vs psf springrates.
all incl.
ics springs, oillevel etc.
all incl.
I want to change the spring to drop fork pressure by 10 psi. How do I figure that out?
Why do you want to do this, what are you trying to achieve? What spring do you want to change?
Lighter balance spring I think he's saying so he can run lower pressure ?
If you were running .49 springs in your other bike that makes me think you have the proper balance spring in the psf.
Is there a specific issue you are trying to correct or do you need improvement in a specific area?
Your weight  would be helpful as well.
