01 rm 250 float issues
My overflow is leaking when I cut the gas on I'm thinking my float is hung up how do fix it? I tapped lightly with a screw and still leaking out the overflow
Pull the carb and remove the float bowl on the bottom. Once that's off lift the float and see if the needle is moving or if it's stuck. Also it could just be a worn needle and seat so you should pull the float and the needle and check for grooves on the needle.
