xr400 usd conversion and aftermarket tanks
hey folks
seems the wife and i may have a chance to move to n/w western australia for a bit... i d be in for a bigger gas tank... prolly the clarke tank... since my 97 xr4 has an emig stem / 2008 crf450 sticks does anyone know if i ll have any clearance issues... don t wanna drop 200 + on a new tank to find out that it won t work out perfect... has anyone done this mod ??
cheers
If it does hit, should be simple enough to take a heat gun to it and carefully mold the tank to clear.
Pretty sure the Clarke will actually give you more clearance than the stock tank. Otherwise, an aftermarket lower triple that has bolts oriented in a different configuration than the stock triple is another way to gain more tank clearance
It would be cheaper to buy another XR4 when you get here than bringing yours over. The cost is rediculas, up to $5000 aus. You could buy an XR4 road registered for about $1500 when you get here.
haven t seen any decent XR4 s in oz for under 3 K or so... mine will ship free as part of the job move... i ll actually be taking two bikes, mine and the missus..
No, you don't understand, the bikes will have to go through ADR compliance through a RAW workshop which means it will need to have everything changed to Australian standards, tyres, lights, emissions, intake, exhaust.
My partner is from NJ & she has a CBR1000RR & we have been looking into importing it, door to door including all inspections & fees to NSW best price I could find was $5000.
I have five XR4's 2001 immaculate, plated cost me $1600, 1999 which had a damaged seat cost me $950 delivered from 1000k's away, 1998 model running for parts $400 two 1997 models bush bashers $800 & $500. Look around a bit more, they're there. Try 'Gumtree.com.au'
Look up ADR compliancing & RAW workshops, save yourself some headache
different situation here mate.... don t have time to explain at the moment but i ll drop you a PM later
cheers
I have the same fork setup and run an IMS tank. It really depends on where you placed your steering stops. I never put stops back on mine and it barely hits lock to lock. It's on the to do list tho.
