KYB Yamaha bottoming cones changes
Any info out there on if the 2014 lower fork ( in the YZ250F)is the same as the fork fitted to the YZ 250 2 stroke style fork 2007-14 ??Part numbers are not the same..
Thanks in advance...
Sent from my iPhone using Thumper Talk
The bottoming piston and cone is bigger on the 250/450f than the 2 stroke
Longer?? Or larger diameter ?? Or both??
Any one know if there is any way to buy the 2014 YZ 250F/450F type??
Thanks heaps for the info!!
Huck valves.
Expensive but worth the money
Thanks 24, that tells me what I needed to know.
Measured bottoming piston at 29mm dia. on 2014 450F
Any takes on a 250 2t diameter?
