rm250 noise
I have just bought this bike and having had some trouble with setting up the powervalve on my 2001 rm250 im wondering if there still a bit tight or if the governor/actuator is tired. they open every time now they have lossened off a bit via the spring but after a decent warm up and when I give it the first wide open throttle there a bit of hesisation and a noise that coincides with when the powervalves open. it only does this once for a second then it clears its throat and all is well. is this normal? do the powervalve governors sometimes make a bit of a noise if the part is worn or if the valves are maybe covered in spooge? I know the motor is fresh inc the gearbox and it sounds nothing like  bearing failiure or piston slap. almost like a chain rubbing on the chainguard. as I say it goes away after the initial run a full throttle. the best way to describe the noise is like a chattering noise. im wondering now if its maybe the clutch. as its a new bike to me I don't know if its a normal noise or not, I know there not exactly mechaniccly silent. any ideas be greatly appreciated
Can you post a vid of it.
The best thing to do, and only if you are handy with a wrench, is to get a manual and strp it. Replace the seals if any and clean it all up.
well that's the plan although the motor has only about 30 hrs on it. it has a case saver behind the front sprocket/chain guard. it also has sign s of chain rub and looks extremely close to the chain. im gonna try run up the road without it fitted ill let you know how it goes
Edited by mgtkr1
