CR500 Carb Size
Hi, I have a 1988 Cr500r that i recently restored. I have determined that the PJ carb is a lost cause and has to go. There are several pwk carb sizes (38mm, 39mm, 40.50mm) and I was wondering what size would fit a stock carb mount, or is that the inside diameter and they are all the same outside diameter? Anyone that can shed some light on this please do!
The external dimensions will stay the same if you don't switch brands of carbs.
