DRZ400E Jetting Question
I got my bike in Jan this yr and it worked well and idled well except for a bog.
Problem: My bike won't idle after the following mods. Other than that it works much better under power.
2006 DRZ400E
elevation 0 to 400ft
Keihin FCR Carb (Not MX version)
I did the Coast Enrichment mod.  I did plug off the 3 holes
I did the Eddie Mod to get rid of the bog.
3x3 air box mod
Put a bigger end cap on the stock exhaust (much more air flow now).
160 main jet
Stock DXP needle clip 5
48 pilot jet
2 turns fuel screw
I frigged with the idle screw a bit but can't get it to idle.
Anyone have a solution for this? Thanks!
I emailed Eddie directly this morning and he said.........
"its way to rich if you plugged all 3 holes and didnt change the pilot air jet. you need to connect the 2 nipples at the rear of the carb together with a looped piece of unkinked hose."
I'll try this tonight.
It worked. The bike work awesome tonight!
It worked. The bike worked awesome tonight!
