How do you guys clean behind your flywheel cover?
Went riding last weekend and it was really really wet. Like 1 foot deep puddles and everything up in Belfair, WA. Came home and while unloading my bike I noticed muddy water dripping out of behind my flywheel cover. I was like oh ok my gasket must be toast from me re using it 4 times. It's not bad behind there just annoyed stuff got in there. It's like dried muddy water in there. I was just gonna use compressed air. Is this safe?
This happens on my bike as well.  I've always just pulled the cover and used parts cleaner.  I've also had the flywheel start to develop some rust so I pull that, clean it using wd-40 and a brillo pad, then spray it down with parts cleaner.
Ok so it is safe to spray parts cleaner and wd-40 in there? I was gonna douse the thing with wd40 and then let it sit for 20 min then rinse. Won't hurt anything?
The stock plastic cover, it will warp and water gets in. Buy a Boyesen cover which is aluminum...
Thanks. Any input about safety of using h2o & wd40 to cleanse in there? Obviously use low pressure h2o.
2003 YZ250 W/07' 450F SSS suspension. Wossner top end. Stock everything else on eng. #8 slide. PC plat. 2 pipe & R304 shorty=mx. Stock exh.=woods. VFORCE3 complete. 4 stroke front fend. & # plate. WC elite perch. Renthal 7/8 tall CR bars. Much more....
Like someone already stated, I also use brake clean...
Ok got it. Sorry Ive OCD about my bike
I would recommend trying to use a contact cleaner that says it won't attack rubber or plastic.  Remember that you have a crank seal under there and the stator windings are a varnish coated  wire.  Brake cleaner can sometimes damage rubber and plastic...
Something like this:  http://www.wd40specialist.com/products/contact-cleaner/
Edited by mylesc
just wd 40, blast it out with air, wd40, blast it out again wipe off any excess all done.
That's what I did
