1992 DR 350 is lowered. How to get it to stock height?
My DR 350 looks like it is a few inches lower in the back than its supposed to be. I dont know what to replace. Do i need a bigger shock spring? Or new shock linkages? Hopefully someone out their will know more than i do about this. There are pictures below showing the suspension components on my bike and a compatison between my bike height, and a stock bike height. Thanks guys
ImageUploadedByThumper Talk1399249183.288729.jpgImageUploadedByThumper Talk1399249220.629412.jpgImageUploadedByThumper Talk1399249364.576669.jpgImageUploadedByThumper Talk1399249777.666532.jpg
measure the rear linkages to make sure there the orignal length.  Some companies make a longer rear linkage which allows the bike to sit about two inches lower.  The linkage that does this is only a few mm longer than original.  If they are the original linkages, I would check your shock to make sure its not too worn out.
Good Luck
Edited by enduro350rider
