My cr125 has no power after rebuild
I just got done almost fully rebuilding a 1991 cr125 and when I went to go ride it, it just had no power at all. I cranked the throttle and it would hardly accelerate and kind of bogged. And it would never get into the power band. What is wrong? Is it the jetting? If so what jets should I change and should I go bigger or smaller? Or is it an engine problem like the timing or power valves? Any help would be appreciated.
I'm not the best mechanic here but maybe you have a leaky gasket our you installed it wrong?
Is the Piston in the right direction?
I believe so. I have the ring gap in the rear.
Maybe, but I just put all new gaskets in it
I'm not familiar with the 125, on the 250 the ring gap is on the exhaust side, so I bet you have it right.. did you ride it before the rebuild, or you got the bike with no top end? I see 3 key things to check, make sure your main jet is the right size and not clogged, check your reeds, if they're too open then flip them around, and make sure your power valve is working right, if your powervalve isn't working then you'll never get into the power band
On a side note I'm I'm dealing with the same problem and I think its because I got a piston from the year before and it doesn't have the arch on the front of the piston like my year does
In my experience your bike should still run pretty good with low compression, unless you have no compression at all, just because they rev so fast at high rpm the compression can't leak out fast enough if that makes sense, just makes it super hard to start, my ex has an old yz80, had like 30 pounds on a compression test, should be like 150, so way bad, was gonna rebuild it for her then she broke up with me, her loss lol, its nearly impossible to start, but when it gets goin it will still power wheelie in the powerband and makes decent power
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
