41 mm carb on big bore 440 jetting
I got a drz with a big bore kit stage one cams 3x mod mdr header I am going to put a 41 mm carb on any one know what the jetting should be at sea level
165 mj 45 pj, EMR needle on clip 3. Remove the pilot air.2 turns out on the fuel screw.this would be a good starting point. You might still need to go richer on the mj. Make sure your squirt duration is around 1 sec
Edited by mickeydee
Yes I was thinking 170~175 mj...and clip 4 Emr needle
Edited by Craigo 485sm
With Craigo485(sm)
The 175 seemed to deliver
