How To Adjust the CRF 150 r 2008 Air Forks
what is standard of CRF 150 r air pressure
thank you
They aren't air forks. The screws are to bleed air out of the forks while it is on a stand, front wheel fully extended.
and how about oil level of out tube forks
350 cc is ok ??
thanks
What type of riding are you doing? Fork fluid should be measures with the spring out and fully compressed. Measure from top of outer fork where the cap screws on to oil level. Most will be 100-120mm depending on rider, valving and type of riding.
You need a service manual!
Edited by weantright
