hat is standard nitrogen of Kx 85 rear shock
How To Adjust the KX 85 rear shock nitrogen
what is standard nitrogen of Kx 85 rear shock
thank you
thank you
Without a special lossless connector, YOU can't adjust the pressure. Don't even put a gauge on it, that alone will lose enough pressure to cause damage to the shock if ridden.
^^^ This!
That cylinder is so small.  Only takes a second for all the nitro to come out, or go in for that matter.  Last i checked it was 20 dollars at the bike shop to have it filled properly in my area.  It's worth a 20 spot.
