2002 CR125 carb choice
I recently got a 2002 CR125 that needed a rebuild. I will be finishing it this week to go ride on the weekend. But before I do I have a question. If my goal is to have a broader powerband, should I swap the stock carb with the old 38mm Mikuni that came on my 05' CR250? Should I even bother? I also go my hands on a 2005 CR125 airboot.
Edited by Crazyced
Swap in the 05 airboot and then take the JD Jetting 38mm pwk off of your 05 250 and put it on the 125.  Put a 48 pilot in it (if you are running at sea level) and then the Blue needle in the 4th clip position with a 182 or 185(maybe as rich as 188) main.  If you do that, you will be ordering another JD carb for the 125 :)
Edited by frdbtr
Just to report, it seems like the previous owner already swapped the carb to a 38mm. Although I didn't check for any numbers or markings, I measured the throat with a caliper and it came out as high 37mm so presumably it's a 38mm carb. It's still on a 400 main and 32 pilot though.
Edited by Crazyced
