CR250 1989 Questions
Hi there
  I am new to the forum, I have not used forums for several years so I would like to come on here and hopefully get some help with my 89 cr!
I have owned many bikes, and as a youth I owned a cr80 and a rm125 to name a few.
More recently I am involved more in the vintage bike scene, and recently I have made myself a BSA 500cc single from autojumbe/ebay parts.
So recently I thought I would get another crosser.
Edited by MPMPMPMP
Thats a picture of the bike there ^^^
I thought I would ask a couple of questions and maybe get some help.
First question is regarding the vin
I am in the UK and the vin on the frame is HM ME03-21033xx
between the numbers is these squares with crosses in them
engine is
ME 03E etc
All the vin refs i found online say it should be JH2 or somehting like that or K
So seems my frame number is a bit strange. Can anyone enlighten me??
Also one of the 6 clutch basket bolts is snapped off, I have seen replacement baskets but they look smooth where the bolts go in, whereas the honda one is
not. Which years are compatible with the 89cr? are there many compatible baskets?
I have had the bike running, goes well, but for some reason when it wants to run it starts first kick, but sometimes it decides it doesent want to run and it is as dead as a dodo.
it has good spark, carb is clean, fuel is going in, seems strange how it dies like that.
Thanks for any help
heres another picture
the exhaust is in bad shape, and the forks leak. but the piston and mains/big end are good
I have a similar dodo problem with my 1988 CR250. While riding last weekend it shut off when coasting down a hill.. wouldn't start even after towing it for a mile trying to roll start it.. I dumped it on its side, then it fired right up and ran like a top.
I cleaned the carb out when I got home and found the float level was way way too high.. if you tipped the bike much at all fuel would spill out the overflow. I am thinking maybe it was flooding the motor sometimes. It starts right up now, so I will find out next time I ride if it worked out. Did you check the floats? I cleaned out the petcock too just to make sure, it was full of jet-clogging junk.
Im not sure what your question is on the VIN number. is that causing a problem?
Hi there
   yea i will have a look at the float level, good one
re the vin, its for the perpose of buying spares, I wanted to see if i had some sort of model variation with the wierd vin.
as i understand it it should say rk or something like that, but it does not which is wierd.
cheers
VIN numbers start with JH2. The J is for Japan, the H is for Honda, and the 2 is for motorcycle.
The ME03 is an engine number, so I'd bet your engine number is what you are seeing on the frame. The vin for the bike can't be ME03 because when you decode that it wouldn't make any sense.
yes thats the strange thing,
I have the engine number which is meo3e
but yea on the frame its
HM MEO3-21xxxxx
there are squares with crosses in between the gaps to bring it up to 16 characters
I don't know what the deal is there.
As for finding parts, you should just be able to look up "1989 CR250" and that would be correct. The pic of your bike looks exactly like the US CR 250 for that year. 1988 and 1990 bikes were different, so 1989 would be correct for your bike.
I recently traded a POS raptor 660 for an 89 cr 250, and can't find a service manual anywhere, does anyone have a PDF? Also what is the fork oil capacity? And what is the recommended jetting for a vented air box twin lair filter and an Fmf gnarly pipe?
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
