The birth of a brand new baby stroker motor... video
Well, there's one more in the world now. We fired Jamie's new 462 stroker and videoed it just for fun. We're hoping for some good numbers as is but we still have some parts to buy.  An MRD exhaust and a 41 FCR. We have a pretty good start with a 4mm crank, a 434 CW big bore, thin base gasket, Web Cams 539 in.  540 ex. with slotted sprockets 107in  107ex., all Ferrea valves with 1mm over intakes, and a hi velocity port job with full radius valve seats, bronze guides, good springs with titanium retainers. The plan is to dyno it as is then change the pipe and see what the difference really is.
Edited by james509
  • Like 7
Well, there's one more in the world now. We fired Jamie's new 462 stroker and videoed it just for fun. We're hoping for some good numbers as is but we still have some parts to buy. An MRD exhaust and a 41 FCR. We have quite a pretty good start with a 4mm crank, a 434 CW big bore, thin base gasket, Web Cams 539 in. 540 ex. with slotted sprockets 107in 107ex., all Ferrea valves with 1mm over intakes, and a hi velocity port job with full radius valve seats, bronze guides, good springs with titanium retainers. The plan is to dyno it as is then change the pipe and see what the difference really is.
numbers wise what would a build like that cost a person? Just ballpark? Thanks
Just from memory,  prices should be pretty close.
crank                   350
big bore               425
cams                    400
slotted sprockets  175
gaskets  oem         60
valves                   160
guides                    48
spring kit              140
porting                  300
labor to rebuild     300
total                             2358
This stuff adds up pretty fast. Some of the stuff we could have done without, like guides, valves and slotted sprockets but we wanted to do the best engine we could build.
  • Like 3
Nice work James...Should start a betting ring going for guessing the HP, probably will be fairly average with the current pipe....
Definitely subscribed..... :thumbsup:
crank                   350
big bore               425
cams                    400
gaskets  oem         60
valves                   160
guides                    48
spring kit              140
porting                  300
total                             2358
whos "we"? do you work in a shop? if i didnt have to buy the carb i'd definitely do a stroker...
Yea, I work in service at a shop that sells Suzuki, Honda, Beta and Husqvarna. I also own a small motorcycle oriented machine shop. If you have at least a 39 FCR, a stroker will still make a lot of power.
Man does this thing run AMAZING!!!! I think the best part of it is the awesome power curve, massive power esp from about 6500 rpm and up. I'm sure I owe that to the cyl head porting by James509. This guy does outstanding work. I would HIGHLY RECOMMEND him if you want one of the fastest DRZ's around.
