Xr600 610cc fcr jetting?
Hi ive got a 98 xr600 im building engine its got a 41mm klein fcr mx carb fmf power bomb header with fmf q4 muffler with spark resister kibblewhite titanium valve spring kit black diamond valves x9 grind megacycles hardfaced cam auto decomp removed hard faced rockers 610cc 98mm ceramic coated jp 10:5.1 piston hot rod coneting rod I will be running 98 octane only.I need an idea what jetting set up I should use does anyone have the same set up?
