KLR 650 Vibration?
I was all set to buy a new KLR 650 last weekend.  Then I did several hours of reading the archives on threads of KLR 650 vs. DR650.
A few threads had said that the DR 650 has the following items that the KLR does not:
  1. Balancer shaft in the engine that makes the DR650 engine run smoother with less vibration compared to the KLR 650
  2. Rubber mounts in the foot pegs to eliminate vibration in the pegs.
  3. Rubber in the triple clamp to eliminate vibration in the handle bars.
I owned a 2007 DR650 for a year and liked it a lot.   The reason I was wanting to get the KLR this time is because while I enjoyed the DR650 road manners I initially got the impression from reading this forum that the KLR 650 would be even smoother on the road than the DR650.   Although I won't ever ride more than 50 miles in a day I want the KLR IF it will be a smoother and less fatiguing ride on the road.
Now after reading the vibration factors enumerated above it seems like the KLR 650 would have more vibration and thus a less enjoyable ride with more fatigue.  Vibration and smoothness are clearly very important factors for me.
It has been said that the KLR is likely a better adventure bike than the DR 650 but I won't be going on any long rides so adventure capability is not an important factor for me.
Is it really true that based on the items enumerated above that the KLR 650 will have more vibration than the KLR?
Is the DR650 a smoother  and less fatiguing ride on the road than the KLR 650?
Are there other factors than come in to play for easier road riding for these two bikes?
Thank you very much for your insight and experience.  It is greatly appreciated.
I've never ridden the DR so I can't compare the two.
The KLR also has a counter balancer, and rubber, but not rubber mounted pegs.
The handlebars are not rubber mounted. I notice uncomfortable vibration off road but not on road in the handlebars.
Vibration is pretty subjective to the rider. I think I'm probably more sensitive than most.
I was in the opposite situation, KLR vs. DR, had a KLR before so stuck with the devil I knew. I ride mostly off road.
Mike
mine is as smooth or smoother than the DRs I've ridden. I would say.... functionally no difference. but, first off.... be aware that a new one will be rougher running than the same bike 3000 miles later.... they just are.  second,,, engine tuning will reduce vibes on the klr: a careful setting of the valves so the intakes match each other & exhaust match each other, an iridium plug, and the carb is set way lean from the factory & needs to be slightly richened (22 cent mod). one thing that really helps is a 685/688/705 piston... all of these kits reduce piston weight.
maybe consider a used bike with some of these things already done.
maybe ride a couple examples
for what it's worth, my klr with full fuel (5.7 gal, measured) weighs 410 with textile saddlebags & tank bag, HT crash bars, full complement of tools, tire kit & compressor. my buddies stock DR was 386.
the forks need to be properly serviced in order to be reasonable. they work ok if serviced. they work great with Ricor valves. the klr seat is junk.
oh yeah.... 16 tooth countershaft sprocket for the highway is good too
and tire choice plays a part. I have 2 sets of wheels, TKC or MT21  for mainly dirt trips and AT90 Scorpions for road trips with minimal dirt... the difference is quite prononuced.  the TKCs produce more vibes than my engine
Edited by Beezerboy
  • Similar Content
    • By J.P.C.
      2014 New Edition KLR650
      Ridden mostly on-road commuting to work.
      5900 miles (will increase as I am still riding it)
      Thermo bob 2
      EM Doo hickey & torsion spring
      JNS skid plate
      SW Motech crash bars
      SW Motech center stand
      Moose luggage racks
      Pelican 1550 cases with Caribou case liners
      MadStad windscreen
      LeoVince exhaust
      Pro taper evo handlebars
      Uni air filter
      Touratech headlight guard
      HTP master cylinder guard
      New Bridgestone Trail Wing tires
      LED dash lights
      Aprilia mirrors
      Top gun 7.4kg rear shock spring
      Jetted for 8000 ft altitude (140 main)
      Extra Parts included:
      Stock Exhaust
      Stock Tires (only approx 200 miles on these before I changed them)
      Stock Windscreen
      Stock Hand guards
      Stock Skid plate
      Stock Mirrors
      16t sprocket
      Stock Rear shock spring
      Carb jets: 138, 142.5, 145
      Bike has been taken care of. Only damage is 2 small scratches on tank from leaning against it with belt buckle. Has been stored outside, but covered.
    • By Patrick McKenzie
      The radiator fan isn’t starting up, even though none of the fuses or connections between the battery, fan and radiator are bad. I figured it has to be the fan relay, but none of the diagrams I’ve seen matched up with the wires on the bike. Does anyone know where the fan relay is for this bike?
    • By hrchins
      Hey Thumpers,
      I am swapping forks and need to know what triple clamps / tripple trees will also fit the 93-96 KLX650r forks. Through some research it looks like KLX300 and pre 09 KLX250 clamps will also fit. But given the ambiguous name of these parts (triple/tripple trees/clamps) doing a search to get good info is difficult. And many of the clamps I am finding for sale are rather expensive so just want to make sure I am getting the right part before pulling the trigger. Thanks for your help!
    • By siscoken
      My Klx400 is a great...fun bike to ride off road with a few highway runs in between trails, but I felt I needed something different if I was going to ride the highway with the occasional off road excursions......so now I own a 2002 klr650. What a world of difference between there bikes, but I believe that between these 2 bikes I now have the one bike I was looking for... if that makes sense.
    • By VersuS
      Hello guys. I just got a while ago a KLX650 1996 with about 34,000km.
      I was in the process of adjusting the valve clearance, they were really out of tolerance so I ordered new shims and when removing the camshaft I had the 2 tensionned mechanism removed (automatic camshaft tensioner, and the spring tensioner bolt).
      I am now in the process of re-timing the camshafts but I'm not able to line up the EX and IN line properly, I always seem to be half a tooth off when positioning the crankshaft at TDC.
      Could it be that i've had the lower chain come out of timing? I might have turn the crankshaft with tensionners removed...
      I am including pictures of the camshaft marks and as you notice camera angle makes a difference but what are your thoughts?
      If i cannot put the marks right on spot, is it better to have the intake valve open half a tooth before, or half a tooth after? and what about the exhaust?
      Thanks
      Sebastien
