1995 cr125
hi guys... i have a cr125 and my engine siezed because the piston clips that hold the piston arm to the piston came off and groozed  the top end barrel a little  bit like a small stretch ov about a cubic mm stretching down 20mm.this led to no compression and no run. i have ordered a piston kit to ensure that there is more compression as the old piston and ring was also groozed. will this work or i need a new barrel?checkout where there is a blue marking in the image attachedhonda.cr125_3.jpg
Edited by hmanhuragenni
If you grooved the cylinder walls, you'll need to bore out that cylinder to make it right.
Ur the first person from Zambia I've seen on TTalk.  I work with twin brothers named Jacob and Esau from Zambia.  Good guys, though they are Democrats lol
it did not grooze much just a small stretch of about a nidle size and 2cm from top barrel down.Thanks and sure thing though dont know the twins.looking forwad to it working...its my frst bike and i have been doing alot of research and i rebuilt it myself.it was running perfectly until the clip came off and groozed.
U can only bore so much cause of your power valve. If it's to deep u might look into re sleeving. Like la sleeve. That way u can bore again if u need to. Or it may be the same price to get a big bore kit
OK THANKS LET ME TRY THE NEW PISTON FIRST THEN I WILL DO THE LA SLEEVE
You can't bore a plated cylinder, don't sleeve the cylinder, get it replated.  Not sure who you have that can plate a cylinder there but Lancort has services based in the UK, not sure if you could send it there or not.
http://www.langcourt.com/
