stock spring rates for 2009 ktm 200 xcw
What are the stock spring rates for a 2009 ktm 200 xcw?  Is the fork 4.2 N/mm (0.43kg/mm) and the shock 66N/mm (6.7kg/mm)?
.40 on the front in the w. 6.6 rear.
Edited by E-TECH
OK, sounds good.  How do you know for sure?  Your name seems like you might be a tuner.  Not challenging you, just want to make sure before I order some springs.  I'm trying to avoid tearing the bike down to check the springs directly since we're riding a lot now.
The springs are not marked.
Have your dealer check the settings list.
You can count coils and take good measurements and plug it into a comp. program and it will give the rate.
Call CSR susp. 800 795 1586 for the correct answer and springs
