Lighting Stator advice for 2T
I don't ride much during the summer due to COPD and asthma it's just too damn hot. I would like to start riding at night when it cools off more like 60* instead of 90* . Any suggestions on a light setup and stator to run them. No cheap chinese stuff . Actually thought of getting a light and housing off an old XR or something , but i'm sure there are better looking and brighter setups out there with the LED's. Wanting it for my CR250 .
Come on over to the dark side Beau where orange is the new red :smirk:.   The bike will come with everything you need to make lighting easy ;)
  • Like 3
:lol:  That's awesome. I enjoy wrenching on my bike but not that much .  :p  I've never rode a KTM i'd give it a shot, they come with air conditioning too ?
I think the A/C has been proposed for the '16 models :) But if they release A/C before direct injection I'm going to be PO'ed...lol
  • Like 2
No doubt i want a bolt on EFI system for my 250 and a supercharger , with A/C of course .  :thumbsup:
Anyway, getting back to the topic.  Before I bought a KTM I was considering a used cr.  I was also considering a new yz.  I researched this extensively and it seemed the "go to" lighting consensus was Baja Designs or Enduro Engineering.
Also, at the time I found this site in the UK.  I contacted them and told them I didn't need a street legal kit, just some offroad lighting for a '13 yz-250.  They quoted me around $500 with shipping included:
http://www.proracing.co.uk/xc_lighting_honda_cr125_250_500.htm
Yea i don't want all of that , My last bike i just rigged it up with 2 led flashlights and actually worked pretty good . I just used them when i was out on a trail and it started getting dark . So i didn't have to ride like a maniac getting back to my truck.
I know you said you didn't want anything cheap, but did you see what I did to the cr and the kx?
No i didn't see, i don't mind thrifty but not chinese 4 dollars break in 2 weeks cheap  :lol:
Just scroll down past the mechanical stuff on this page until you get to the electrical. I have this taillight on my KTM and I've looped the bike out at least twice and it has stood up...
http://www.thumpertalk.com/topic/1078156-spring-rebuild-pictorial/page-6
Edited by Fattonz
Check out Tusk products.  They offer a pretty descent enduro lighting kit.  Or you could wing it yourself and simply hook up a hot wire to a voltage regulator and a capacitor.  LED is definitely the way to go. :devil:
Cool i saved that page i will probably refer to it as i do mine. Good job  :thumbsup:
O yes for sure going led .
I could always go back to my two LED flashlight setup  :lol:
You can take my set up a step farther, and as Devil says run a wire from the hot lead of the stator to a regulator/rectifier then after the rectifier install a 1000uF capacitor rated 16 or 25 volts between the positive and negative leads.....this will give you the regulated 14-15 volts DC you need to keep the battery at full charge and negate having to use a battery tender.
Electrical components are dirt cheap:
Regulator/rectifier:
http://www.ebay.ca/itm/270999908880?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Capacitor:
http://www.ebay.ca/itm/10-x-1000uF-16V-105C-Radial-Electrolytic-Capacitor-/260814972891?pt=LH_DefaultDomain_0&hash=item3cb9c8a7db&_uhb=1
It's a LOT simpler than it sounds ;)
Edited by Fattonz
Capacitor:
I'm an electrical idiot but may try it out.
I don't think you want to tap into the ignition circuit.  Many CRs don't have an accessory circuit.  What year is the bike?
  • Similar Content
    • By Moto Dave
      I want to know which headlight to buy to increase the brightness and quality of my headlight.  This is my configuration.
      I just upgraded to a RickyStator dual stator.  The previous owner installed a Baja Designs dual sport kit.  I successfully installed the stator, the DC system works great working my turn signals, and tail light.  As for the AC circuit, I wired the BD Headlight direct to the stock green (ground) and blue (hot AC) wires, and it works.  In order to get the high low beam working, I have now ordered a relay switch to allow the light to go high beam and low beam.
      I've read that I can use a 100 w lamp now, but I don't know if this is halogen, LED, or whatever.  I'd really like to know what you recommend.
    • By cgifool
      hi there, I recently bought the ricky stator ltz400 stator after having seen a post confirming that after soldering the old harness on the new stator worked.
      unfortunately, after I completed my work, the bike no longer starts. im really not sure where to start. I unplugged the connector with the blue/green/white/grey wires from the box under the seat, and managed to test the blue/green resistance at 0.52 on whatever resistance scale my meter was on. I did not test the black/white wires.
      the battery is fully charged, the main fuse is intact, the starter runs strongly, the bike just doesnt fire.. it ran fine before taking it apart, so im sure i've messed up the job somewhere along the line. Im going to recheck to make sure I didnt reverse some wires along the way. That cloth insulation is annoying, I finally ended up using an exacto knife to carefully trim it off.
      thanks,
      David Mitchell
      Austin, TX
      01 drz400s
      78 r100/7
    • By ohgood
      ****edited, updated****
      this is the old issue:
      bought the drz august of last year. stator failed, or was failing at time of purchse.
      replaced stator mileage 8500 or so.
      today, oil changed, burnt smell from oil. milage 11968 (12000). stator has failed again. never overheated, oil and filter changed religiously at or before 1,000 miles.
      went for a short ride, and the battery discharged completely at some point. bump started, rode home.
      i've contacted rickystator to see if they'll honor the purchase, and diagnose the failure if i ship it to them at my expense.
      i'll update as there is progress.
      -aggrevated
      rickystator id'd the stator as their own from my emailed picture, while on the phone with me. they shipped a replacement on tuesday, and it was in my mailbox today (thursday) when i got home. no questions, no paying for postage (which I offered both ways), no problems.
      this, is customer service.
      slapped in the new stator, 12.9V key on, not running, 14V running. excellent
    • By mitchp
      I have a failed stator. Been looking around for a replacement. I found a replacement from a company called Ricky Stator. The price for the unit is very reasonable, $125. Anybody have any feedback on this part? Thanks in advance, Mitch
    • By e46fanatic
      My stator died, so I ordered a new one and installed it last night. Everyone says go with Ricky stator, but I couldn't see paying $250 for a drz stator. So I found one on ebay that sounded alright and was only $104 shipped. But really, what are the differences? Have many people been burned by faulty aftermarket stators?
      This is the one I bought:
      http://www.ebay.com/...984.m1497.l2649
