Yosh MJN carb
Anybody have any experience with the carb from Yoshimura?
Edited by Subbieman
Yeah , typical Yoshi .. Over Priced
I would go for the classic on drz400(and many other bikes) Keihin FcrMX39mm carb , easiest to find parts , jets , needles etc , easiest to find info on how to jet it compared to the Mikuni - Yoshimura TMR40mm carb .
Also for the price Yoshi wants you can get an FcrMX39mm varb + parts to install it on drz400 and keep the change to jet it properly on a dyno and have a fancy meal on a good restaurant after the dyno run !
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
