Suspension
I have a 2006 YZ 250F I just put front fork seals in and the forks will not depress  i put 350cc of oil in each fork PLEASE HELP!!!!!!  have a riding weekend planed this weekend  :banghead:
look again step by step at what you did, that would be troubleshooting 101. First time doing it? Did you follow the proper steps? Good luck
yeah don't freak out...
1) take wheel off, do the forks compress normally by hand?
2) If yes, your forks are probably in bind ie are they at the same level in the tripples and did you torque the front wheel correctly?
3) If that's good then simply open them fork and re-check what you did. If you've gotten this far, it could take you 30min per fork to open up and close again.
Edited by etxxz
