I need a few torque specs 2013 RM-Z250
My manual is at a race shop an hour away. I needed to put a new clutch basket in and I need a few torque specs if someone has a manual handy and could help me out. I'm looking for:
Clutch inner hub/basket retaining bolt (large center bolt)
Clutch pressure plate/spring bolts
Clutch cover bolts
Any help would be much appreciated,
Matt
Here you go.
Clutch sleeve hub nut: 65ft lbs.
Clutch spring bolt set: 7ft lbs
Clutch cover bolts:8ft lbs
I think I made a mistake. The clutch cover is supposed to be 8 in lbs
Perfect. Thank you so much.
