Crf230 cr250 front forks and xr 350 rear shock
Okay new project got a 2005 crf230 for 250 dollars yes just 250 cheap but was blew up has bad cam rockers jug and piston so for now im building a roller until i see how it goes here is a list of parts i bought
1989 cr 250 front forks triple tire axle and brakes assy 75 dollar
1985 xr350 rear shock 80 dollars ebay
Now the front forks i made a spacer the barrens seem to be the same and there inverted forks 1st year but still better then nothing i would guess
and the xr 350  i think 83-85 works it was bolt on i trimmed the right side with a grinder so i could route my cable pics will be up soon ..
If any one has any other ideas or mods i should do please say i maybe a big bore and cam  front fork emulators ??? anything ill listen
If you can be on your interest I have done this in my 05 crf230:
Crf150r Forks.
85 xr350r rear shock.
Grind#: 282 Cam( Webcam).
67mm Wossener high compression piston.
120 Main jet +45 pilot, the needle in the fourth notch starting from above. Then a series of other minor edits. Obviously I removed the snorkel and I have modified the stock exhaust.
Edited by Crossplayer
P. s.
The rear disc brake is not a mod.. Crf230 Italian version has this from the factory.
I have only installed the wave discs
(Sorry for my English)
