ktm cylinder base gasket
hi!
in interested to know whats hapening/changing
if on your bike if you change your gasket's thickness
i can see that there are available o,75-0,50-0,40-0,20
so whats the story?
Chose the one that allows the piston TDC to be right at the top of cylinder. The effect of fooling with a different height changes the port timing and compression ratio but how it will change the way it runs IDK.
