Poor Man's Triple Clamp Bar Offset
i have done this on another XR in the past and just did it again for my 600 so I figure I'd share. I used a 1" wide 3/16" steel bar with three holes in it to offset the bar mount forward by one hole spacing. I machined the top of my OEM clamp (parting line of the 7/8" bar clamp portion) by 3/16" and machined the semi-circle off the bottom of the Fat Bar adapters. Used one extra screw and nut to attach the front hole of the adapter to the flat bar and there you have it..... This puts the bars over your fork tubes, which is similar to where aftermarket clamps would. You could also get away with skipping the machining on the OEM clamp, just means your bar height is up a little more.....
  • Like 2
