2013 kx450f compatibility?
Hey fellas I just purchased a 2013 kx450f with a locked motor. I haven't pulled the motor off yet to see all the damage but I was wondering if I could use any internals from previous years kx450f's
I just did this with a 2012 with a 2010 engine, from 2009 till now will bolt straight in as a complete unit, between the years there are a few differences in the gearbox and cylinder, from 2009 till now the head and valves are the same in 2012 the intake cam is different ( more power), my 2010 is running perfect with all the 12 wiring and mapping.
Thanks for the response. You mentioned the gearbox, that's what I'm most concerned about. Someone intentionally ran it without oil so I'm assuming the gears are trashed. Do you think I can use the gearbox from an older kxf? I'm trying to save coin wherever possible.
You can use any gearbox from 2009 till now, you just need the same year cylinder to suit it, the head is the same from 09 till now.
