Amsoil Shock Therapy Oil
I like it better than Maxima and I used maxima for 20+ years:)
It lasts alot longer.
I was wondering if anyone uses this stuff. If so, how is it? How does it compare to Maxima fork and shock oil?
Good stuff. been using it for years
I'm about to do a fork & shock rebuild and was wondering with what oil would I use. I guess this opinion is good to know. I need 3 & 5 wt for the fork and 3 wt for the shock, would they have it in those weights?
No, they only have 5 and 10wt fluid. Just use the 5wt on both the forks and shock.
You will never know the difference betweem 3 and 5wt fluid.
I've used about a hundred gallons of AmsOil ...nothing wrong with it ....holds up good in the shock.
I now use Maxima 85/150 racing fork oil....19 centistokes ....and slick.
I use Motul shock oil V.I. Of 400
Point is what makes a fork oil good is slickness.and they don't have a good V.I. Number so you don't want to use it in a shock.
But in a shock there is a lot of heat....so you need a high V.I
