TTR 230 Spoke Torque
Ok, so I replaced all the spokes with OEM's on the rear wheel of my son's
2006 TTR 230, as I followed the tightening and torquing patterns that I read,
being from loose, 1/4 turn on 1, skip 2spokes, 1/4 on the next until up to
the spec of 3.25 NM as in the service manual, the rim has a slight wobble
when complete.  When it was just snug, I adjusted for trueness, had it very
nice, then proceeded up to torque by 1/4 turn and following pattern as above.
Now that it is torqued, how do I remove the wobble and still be torqued properly?
Thanks...
T
Torquing is only applicable on new spokes. And even then as you note, once snugged THEN you have to go and adjust everything however needed to achieve true-ness.
That is the only criteria. Torque doesn't matter then.
Ok, so now that I've torqued them, is it ok to loosen/tighten slightly
as needed to true it up?
Also, many posts that I read indicated a torque of 45-48 in lbs, my service
manual says 28 in lbs, prior to having the manual, I tried to reach 45, and had
one break at 35, so I now have them at 28 as per the manual, will this be good?
T
Edited by 54d18
Thanks, I figured the manual to be right, and the runout is really not that bad, well within spec, just nice to know the proper procedure.
Thanks again,
T
