Shimming valves - TDC
I'm in the process of shimming my valves and I have a question.  I know I started at TDC, but when I took the bolts out of the cam sprocket I had to rotate the primary drive gear bolt  to gain access (just not sure how much).
So when I go to install the Camshaft Holder Assembly back on, I know I need to line up the punch mark for the primary drive gear bolt and also line up the cam sprocket with it's index mark, and have the intake cam lobes facing up - but it still seems like I could be off by 180 (or get lucky and be on)?  Is there a way to tell, what am I missing?
Thanks
Thanks
The crankshaft only knows what the cam tells it.
There is only ONE TDC...set the crank to TDC and then time the cam sprocket to that. Lobes should be facing the rear of the bike and slightly up.
Hint: Use the flywheel to find TDC...inspection port on ignition cover. Much more accurate...
Wow thanks for the quick response, I think I understand what your saying.  Once I align both - I can't be off 180 (or it doesn't really matter).
"Hint: Use the flywheel to find TDC...inspection port on ignition cover. Much more accurate..."
how do you do this, I can't find any info?
thanks
<<The crankshaft only knows what the cam tells it.  There is only ONE TDC...>>
I know what you meant, but it didn't come out right (at least to me) because the thing that's not clear to most is that the pickup coil for the ignition is on the crank and fires every time you hit TDC.  So you can't be 180 out.
All that matters is that the cam marks are lined up at TDC so the cam is in sync with the piston, which is what you were getting at.
Jim.
thanks
 It's the plug on the ignition cover (left side).   You'll see two marks in there a "F" and a "T".  You want the "T".
Jim.
that's a good hint sir. Always a PITA to keep looking on opposite sides of the motor when checking. Thanks!
Learn something everyday!
Yea it is easier to use the fly wheel. Instead of looking over. To see the crank dimple that's covered in oil.
The T and F markings can be hard to see too. What I do is take a sharpie and mark the T, just makes it easier to see. Specially as my eyes get older. Good tip Doc
